Bonnewagon said:Try to find a reprint of HO's wonderful High Performance Engine Building and Blueprint Assembly. Although dated, it is the Pontiac Bible.
Cheapest one I found was on Amazon for $49. That's a used soft cover too.
G-Body_Vet said:It would definitely give you that extra .002-.003" of clearance you may need. I always find it funny when people come out of the wood works to "one-up" each other in those kinds of threads on PY.
67rstbkt said:G-Body_Vet said:It would definitely give you that extra .002-.003" of clearance you may need. I always find it funny when people come out of the wood works to "one-up" each other in those kinds of threads on PY.
I'm going to wait until I can get an accurate measurement before I decide. You really need the right tools when it's down to a thousandth or two. I like the Cometics, but everything I've been reading tells me that they are overkill. Plus, although my block has been decked and the heads are being surfaced , I'm concerned with how "perfect" the mating surfaces need to be. My block has some stuff around the water holes that did not come out. It's minor, but I'm not sure if it's worth risking it with Cometics.
I'm learning a bunch about this, which is good. At least I know all my options now. Hopefully, you won't have to deal with the issue, and if you do, you know all the options now too
G-Body_Vet said:Yeah that's pretty crazy about the surface prep for Cometics. Hopefully my set-up gets built fairly pain-free.
youngdeezy said:oh man, i know you had to feel good seeing your heads like that. you have a solid build going on....me likes 🙂
pontiacgp said:G_Body_Vet....if you have a 200 r4 from an 85 SS it should have a pink tag on it that says 5CQ and it's a transmission that people are looking for..that is an awesome score...I sold one for $400
