If you disconnect the vacuum line for the vents at the intake manifold and apply vacuum with the Mighty Vac, it should hold vacuum. If it doesn't, there is a leak. If it holds vacuum, try to move the HVAC doors inside the car by using the mode switch. You may have to provide additional vacuum by pumping the mighty vac.We're on it today- he swears there's no leaks yet the dash vents don't open- hope something simple got overlooked- we'll be using the techniques mentioned above to fix the overheating- fingers crossed
Mighty vac I assume is a tool for this? Parts store purchase item? Also, when you say use the "mode switch" can you explain? Sorry for my ignorance but thank you for the help!-If you disconnect the vacuum line for the vents at the intake manifold and apply vacuum with the Mighty Vac, it should hold vacuum. If it doesn't, there is a leak. If it holds vacuum, try to move the HVAC doors inside the car by using the mode switch. You may have to provide additional vacuum by pumping the mighty vac.
I thought my unit was alright- I'll check that...
