I have read that, if they do, that is about perfect. I would personally stake the spring on the small weight by tapping and adding a small screw, they can fly off.Shift at 5500
Yes, some of them shift under 5000. I programmed my 4L80 to shift at 6000.Don't they shift at 5000+ rpm?
Hehe. You forget I’m running a 6.2 with variable valve timing. Want to compare torque curves? A properly built Olds should be able to handle 6000 no problem. Let it eat.I would think the stock GN governor would be perfect, depends where they actually shift. Anubis has gone to the dark side where low end torque doesn't exist😁. I love that flat curve and tons of torque right from 2900 rpm. I had my shifts right around 5000 rpm and it worked well with my 214/214 cam. What stall are you going with?
Yeah, if it has been modified and shifts anywhere between 5500 to 6000 rpm should work fine. The governor on the 2004R is trial and error. He has the heavy forged Speedpro pistons on stock rods, I would argue 5500 rpm is better for long durability. I have never drove a 6.2, I would imagine with the right tune they haul big time. The Gen 3/4 truck 5.3 and one beat on 6L I drove sucked awful. It has to be torque management, they all felt way under their power ratings. Probably protecting the 4L70E junk and the 6 spd programming SUCKED. The two 5.3 gen 5's I drove were massively better, night and day.Hehe. You forget I’m running a 6.2 with variable valve timing. Want to compare torque curves? A properly built Olds should be able to handle 6000 no problem. Let it eat.
6? Zing that sumbich up 75 hunnet!Yes, some of them shift under 5000. I programmed my 4L80 to shift at 6000.
You should be able to reuse your linkage and column interlock parts but will need a new lightning rod cable and transmission bracket which is specific to the 4 speed lightning rods. The lightning rods will bolt to your existing sheet metal brackets.Good evening all. Question for the experts about me swapping the th350 to the 200r4. The 442 already has floor shifter, but now putting in lightning rods, what am I required for linkages to have this all set up?
Thanks
