83' 307 olds out- sbc 350 in ?
BrownGP83
317
2
16
Chamberlain,South Dakota
Use a long style water pump on the 350sbc. that is what the factory used on g-bodies[and every thing else from 1970 and up i think] that way the proper brakets and pulleys will be easier to locate. I'm not sure if thepower steering braket from the Olds will bolt to the chev.
dan2286
2,233
4
Cleveland, Ohio
beeterolds said:
why not just go from the 307 to another Olds engine? sure Chevy engines may be cheaper to build but not by much.. Hell i stuffed a 455 in my car for under 800 bucks including the cost of the engine!
I would suggest that also, but he said he already bought a chevy engine. If he wanted to he could sell it and have enough money to get an Olds and it will swap right in.
Blake442
6,866
2,011
Minneapolis
It won't. Good excuse to put in an S-10 manual box... :D
BrownGP83
317
2
16
How hard is it to switch a power steering car to an S-10 manual box?
dan2286
2,233
4
Cleveland, Ohio
Just as easy as swapping parts out. They are bolt in.
BrownGP83
317
2
16
What years will work? Will 4wd work or must it be 2wd/
dan2286
2,233
4
Cleveland, Ohio
That I am not sure of. I think it is from the 80's maybe early 90's S-10's.
mhsmonte
131
Kentucky
83gcut said:
wuz up g-bodies? g-cut here just signed up today, i'm on my 3 rd oldsmobile cutlass with-in 12 yrs. or so ..... so my question is this i bought a sbc 350 with a th350 bolted on long tail.... what can i use off the 307 to power up and go in the 350 once its dropped in? do ya'll have any recomedations on what to retro fit(alternator,water pump, starter,etc....) to the 350 before i drop it in??? any body need a 307 olds motor with tanny..........
When you change your motor mounts I would like to buy your 307 frame mounts. I am putting a 307 Oldsmobile motor in my 1979 Monte Carlo and I am in need of some frame mounts for my 307. If anyone out there has any I would like to purchase them if possible. Email me with information
Jan 7, 2014
4
Hey, I am doing something similar. I am installing a sbc350 in my 78 Olds Delta 88 that had a 350 diesel in it.
I already got the engine installed but im having trouble with the accessory brackets. What model car could I get the a/c bracket that fits on the passanger and also the alternator brackets for the driver side? So that I can use the a/c and alternator from my Oldsmobile on the sbc 350
Thanks
8,832
7,793
Holy old thread Batman! You need the brackets off a caprice or really anything sbc. The question is why would not go Olds 350, 403 or 455. The heavy weight and awful gearing are toreable with nice, flat Olds torque curve. Better plan on a gear and converter swap to move that heavy pig.
