'83 Regal V6 to Truck Chevy 350
You will need the block side mounts of the left.
Cutting this tab off will allow the top mount to fit in easier.
These are the holes you need to bolt the mount into.
Might be a dumb question. But the first picture. What is the one on the Right?
Like what is difference from which they came?
Is that a difference between a Car and Truck?
Thank you for tip on cutting tabs off also.
The right are big block mounts but they will not work in G body's.
Some came in cars some came in trucks.
if you look at them the motor mount bolt hole is in a different location and will not line up with the frame mounts.
Reactions: AlabamaHit
I must be blind i can't really tell....
Don't like right to me they are definitely different from the ones i have used in the past.
That doesn't mean they work work though.
If one side lines up and the other side is a hair off you know you have the wrong ones.
If those are the ones from the truck they won't work
His look like the clamshells I got from a 79 elcamino
Could we measure these to check? From ends to hold and back to hole?
I do not mind buying more. Just junk yards round here are....from lack of better word: pathetic.
They never check for any parts you have ot go there and check and for me that is 45 minutes one way to closest one that might have it lol.
if you could mesaure from the end to the Side of hole like lines? not to center.
OR
Would that even matter? I know the back side to hole would but others might not matter as they could be different per everycar
Where r u located?
I'm not near the car but they slid right in place on the replacement frame mounts for an 86 monte Carlo on an 86 cutlass frame lol
