'83 Regal V6 to Truck Chevy 350
19,992
AlabamaHit
39
6
Here is your mount.
You can see here that your mount is a little bit taller
I get just about 3 inches, 2inches and 2.5 inches measuring the mount
Thank you for that.
I know I can get the brackets from Any G-Body V8 is what I read. But does that literally mean any? So any 305 or 350? Like off malibu or monti?
I am very impressed you have all that stuff like that.
9,193
15,426
Thank you for that.
Any '73 up A/G body SBC will work. Can't remember off hand if '73-'75 BBC is the same (thinking they are.) '77 up B bodys use the same.
L67ss
1,350
420
Remember. You'll need an additional frame mount to frame bolt as the Chevy mounts use 3 bolts each and bop mounts only use 2 each. Also you'll need different through bolts(bolts that hold the clamshell to the frame mount) as Chevy uses longer ones
AlabamaHit
39
6
I sorry I don't really understand what you meant there bro.
The link to ebay is that the right Solid mounts for the frame? I decided to not use the anchor ones I posted on the first post because I don't want to have to fight to change them later on.
I'm going to a junk yard this week to try to find Motor side mounts.
L67ss
1,350
420
Where it bolts to the frame and what holds the motor to them
L67ss
1,350
420
Looks right. Are you gonna street drive?
AlabamaHit
39
6
Yup, just street. 350 I built is just stock other than bored .30.
Sucks I have to buy the engine side new because no junk yard here has them.
