Needs a wipe down for sure. Amazing how much dust shows on the frame. Ugggg
No carb. Fuel injection all the way. I'm not sure I'm going to run knock sensors yet but if I do I'll fit them to the sides of the block like the newer style.
Opinions welcome on that.
Also need some insight on running battery cable
Take a look at the pics. Is it feasible to route it over the frame as shown or should I drill a hole and use grommets in the rear crossmember tucking it against the inner side of the frame notch between that and the rear spring?
View attachment 119386View attachment 119387View attachment 119388
I placed some bushings on frame to get an idea of the clearance. I'm thinking hard about putting the starter solenoid in the trunk so battery cable is only hot when starting and I know I will need to run many additional wires to do this. Darn decisions.
