melloelky thank you... It's an Eastwood product. Some of the plastic adhesion promoters say they are not for urethane products? I don't know. Also since you have been here longer than I, should I ask these questions in paint section or is the build thread ok?I've Never used the epoxy you're using but follow what the paint sheet says as far as a universal promoter goes on all surfaces,prep etc.especially plastics.i don't know what they call for but the tech sheets on paint products is law on procedures in my book.
Use bulldog. It's not cheap but def worth the cost. I started using duplicolor adhesion promoter and it leaves an almost web sometimes when sprayed. I switched to bulldog and haven't looked back.Thank you sir
Will do... ThanksUse bulldog. It's not cheap but def worth the cost. I started using duplicolor adhesion promoter and it leaves an almost web sometimes when sprayed. I switched to bulldog and haven't looked back.
