84' Cutlass pro touring build
Earl's temp a cure 42 row cooler. Not inexpensive but made in America quality. All mounting points have rubber grommets and nylocks to isolate from vibration. Sitting on a foam rubber piece I fabbed up. Disregard the black nylon wrap that is frayed back from ends. Much easier than trying to get it under the fittings and no one will see it anyway.
Drilled and tapped 1/4×20 stainless button heads into frame.
Sorry for crappy pics. Install went very well. No need to hammer cut or curse. It is tight going over the rear end. Suspension at full droop. Btw from my coil over thread I put 4 caster movers under front tires and when I lowered her down it actually dropped about an inch. So the tires were holding it as stated
Some progress. Pre lubed the engine by cranking her over. Only took 3 or 4 short starts (about 10 seconds each) before I had 45 pounds of pressure. Seems kinda high for just cranking as I was expecting maybe 20psi. Since my starter cable is run to the trunk and I didn't do a ground back there yet, this was my answer for an electrical connection. Lol
i think in order for that electrical connection to work it must be clamped to the frame...
Ya lost me. that's the positive cable that I ran with a spare battery cable towards the front of the car where I connected to battery sitting on the floor. Ran ground to batt and engine temporarily
Make sense? It worked fine
I was just messing with ya Tony,please don't clamp that positive cable to the frame..🙂
