Nothing is easy that's for sure. Your last two sentences.... Wow. I consider myself an amateur still learning from every mistake. I appreciate it though. If I can align a door anyone can. Trust me.Dude, I had a hard time installing new door hinges. I could not align anything to save my life! I will not attempt to fix it, I'm sending to a body shop after the motor swap.
Your thread is awesome and I would like to have your ability/skill! Great build!!
90 degree days you worked for a living there good for you..if your high build isn't direct to metal then those break through spots need either a light coat of self etch or spot them in with epoxy and re-coat the panel with high build like you planned.Last 4 days I've been working on block sanding the roof. Had some low spots that I used finishing glaze and honestly some were so small that I think another round of hi build would have taken care of them.
These are days where temps were mid to upper 90's. At least two t shirt changes a day.
Anyway I have questions. Some spots I hit bare metal, others down to epoxy. All lows are gone.
Do I just spot prime the bare metal or would you also lay a thin coat of epoxy on filled areas???
My plan is to do another round of high build and it should be 100%
Thanks Chris... I worked my entire life in boiler rooms. I'm used to the heat but I don't like it. I sweat like no one else. Trying to keep from dripping on work.90 degree days you worked for a living there good for you..if your high build isn't direct to metal then those break through spots need either a light coat of self etch or spot them in with epoxy and re-coat the panel with high build like you planned.
no worries.ask away Tony.high build over filler all day.did you get a tech sheet with the products you're using,a lot of times there labels on products are informative also.Thanks Chris... I worked my entire life in boiler rooms. I'm used to the heat but I don't like it. I sweat like no one else. Trying to keep from dripping on work.
Just wasn't sure if hi build was ok over filler. Stupid, I know.
I've read so much... I should have known that. It's fine on product sheet. Matter of fact I did it on front fenders but it's been so darn long...no worries.ask away Tony.high build over filler all day.did you get a tech sheet with the products you're using,a lot of times there labels on products are informative also.
