Ok, I will likely start with a new fuel tank and sending unit. Do you happen to have a part number or link to the correct throttle bushings for the factory carb? I saw many different ones online, but not sure which one is correct.
I believe the carb and engine was rebuilt back in the late 90's, but it has sat a long time. So it needed freshened up. It was last registered in 2000 I believe.Damn , your problems almost the same as mine.
quick question - your carb has been re-built , by who ? i thinking the previous owner had it done with your comment about carb being loose when you bought it .
just asking , i will be following.
Dave
No temp issues. Bought a new tank and sending unit assembly online, will install once they get here and I have a chance to mess with it. It does have the factory cat; what's an easy way to check it?Any chance the catalytic converter is plugged? Any temperature issues?
yes 442 of that erra do have a certain look to them don,t theyCool car by the way.
In my experience those old pancake or flat bed converters are prone to getting plugged up. Modern converters don't seem to have the same problem. It may well not be your problem but I thought it was worth asking. Here is a little blurb I found online on testing a converter with a vacuum gauge. I encourage you to do your own search and see what you think. I hope this helps. ........
To diagnose a plugged catalytic converter, you can check intake vacuum or exhaust backpressure. To check intake vacuum, connect a vacuum gauge to a vacuum port on the intake manifold. Start the engine and note the vacuum reading at idle. Then increase engine speed to about 2,500 rpm and hold steady. Normal vacuum at idle for most engines should be 18 to 22 inches Hg. When the engine speed is increased there should be a momentary drop in vacuum before it returns to within a couple of inches of the idle reading. If the vacuum reading is 10 percent lower than normal and/or continues to drop as the engine runs, it probably indicates a buildup of backpressure in the exhaust. Remember, though, that intake vacuum can also be affected by retarded ignition timing and valve timing. What's more, some engines are much more sensitive to small changes in intake vacuum than others, so checking backpressure rather than intake vacuum may give you a better indication of what's going on.
