84 Monte SS I bought mostly completed
Ugh, I think I wanna be just as dumb as you lol, that f*%#n sounds awesome
Ha, yeah I went full tilt I think except for getting the cruise control because I didn't like either of their units. But I got the retain acc power/auto headlights, GPS speed/compass sensor, and the bag/tank sensors
I like the led lights were did you purchase them and how much?
Thanks, the shop I work at is a distributor for them. They are $220 for the half halo projector housing and the led/demon eye headlight per pair.
Are they plug and play or do the headlight housings have to modified?plug?
Mine was already trimmed for aftermarket housings since they are thicker than stock so I didn't have to do that to replace what I had in there but you would have to but doesn't take much. The headlight itself mounts pretty easily because it has a spring like piece that holds the bulb in well since it has a fan on the back. I had to slightly spread them to clear the fan but also very easy. Hardest thing is figuring where you want to put the brain and ballasts to keep them clean and dry to just avoid problems. Then running the supplied wiring to the battery to be able to use the demon eye anytime you want.
