Swapped the lowdoller 500 psi transducer out for the Honeywell 1000 psi and changed the needle valve to the smaller one.
Clutch pressure maxes out at about 650psi so I for sure needed the higher pressure sensor and I'm glad I didn't jump to the 1600 because I'd have really poor resolution.
The smaller needle valve gets me about 3/4 turn before it hits saturation so about 3 times as much adjustability.
Also spent some time in the lathe turning a new spud for dads tire machine. He has a 70's Coates 10-10 tire machine and it's not made for rims over 7" wide so this new nut should help it accept a 10" wide rim.
Going to spend some time on the tire machine and put my drag radials on the 15x10 wheels and see where I end up.
