Slipper valve is done
![PXL_20220709_162004549.jpg PXL_20220709_162004549.jpg](https://cdn-0.gbodyforum.com/data/attachments/189/189254-e5d6ea71e83695abea63c6116fd60d18.jpg?hash=5dbqceg2la)
And got the pinion set with .030" shim, it might need .027", depends what the pattern looks like. And got the ring in and set at .007" backlash. It's either good or bad, depends on what cut style of gears these are, and the box didn't come with literature so I gotta do some research.
Otherwise I just gotta pull the pinion out and swap to the press on bearing and bolt the case in, seal the cover and fill with oil.
