I was thinking the same until I re-read his post. Is he having issues with finding an input that reads .5-4.5v on the ECM?
I'm learning more about HP Tuners and stock ECM's following along here than I ever have :0
Yeah Jim worded it more concisely. I have enough 5V supplies, I needed 5V inputs which I initially used the wrong ones. I switched the input pins to fuel tank pressure input and AC pressure input and it works! Although the fuel level sensor pins are 5V signal, they aren't inputs like I thought.
Good news is swapping the pins works. All my added sensors are fully functional now.
Bad news, I had mentioned my interest in going to the track for Wednesday night street drags but I'm postponing that. My fuel pressure is too damn low.
58psi base fuel pressure and 173kpa is 10.5 psi of boost which means the fuel pressure should be 68, its 42, which is like 32 effective when it's really in boost. Ish. Yuck. Bad. Danger. Warning.
Already at 88% injector duty (which is because the fuel pressure isn't keeping up) on e60. There is very low likelihood I will have enough fuel with more boost, more RPM, or true E85. I need more pressure. It holds fine with injector duty cycle is below 70% but it starts falling off pretty fast once I get into the 80% duty cycle range.
I have -6 from the tank to the filter, and filter to the firewall, where it goes to -8 as it Y's into the fuel rails before it Y's back to the regulator. I am going to replace the stretch of -6 with a new piece of -8 from the filter to the firewall and see if that helps. If that isn't enough I will pull the walbro 450 out and swap to a 525 HC pump and go -8 from the tank to the filter also.
There are cases where the pressure is keeping up 1:1 with boost, but you can see in this pull past the snapshot white line where the fuel pressure starts trailing down as it revs through 3rd gear.
I'll get my fuel system patched up and reassess.
Lesson of the day is -6 AN hose and a 450 pump isn't enough to keep up for fuel requirements of a 6.0 with 10psi and 60% ethanol. That's why I spend the time getting these sensors set up. I always THOUGHT it was fine when I would glance at the gauge I had but it's really valuable to see the results as it runs through a pull.
