It looks the same but the body panels fit nicer. I've become a self taught (not)expert on header panel, hood, bumper and headlight adjusting and aligning. If body panel fitting was my occupation, I'd be bankrupt. But it sure is fun. Below is the hood latch back up release cable - crude but it works.
A little tweaking is still needed. The rad intake top was touching the header panel leaving a bump as it was when I got the car(below - bump visible above driver's side high beam.
. Off goes the nose to tweak the rad intake. Apparently the nose flange(header panel) is only to touch the air intake where it's fastened. The area above the grille is 'floating'. Here I realized the bump was still there.
Hardly any difference in the before and after pic.
