unfortunately my car won’t pass regardless originally comes with 5.0 now it has a v6
Thank you I will try this out either way gotta do a tune up on this carFor what its worth, I've had that happen with a distributor rotor making poor contact, the little metal tab was worn and bent away. for some reason it idled revved fine in park but when driving it it acted up. did a cap/rotor and cleaned up the issue.
I had a very similar problem 20+ years ago with my 80 cutlass when it still had the original 3.8. It would idle and rev in park just fine but put it in gear and try to go and it struggled worse than normal, my first thought at the time was that the torque converter was bad. I knew the cat was fine cause it didn't have one. Turns out all the plugs were fouled. Put in 6 new plugs and it was fine.
Thanks I’m definitely gonna try this I haven’t done a tune up on the car yet I have everything alreadyThats probably whats wrong with his. I put new plugs in mine when I finally got it running. Over the last couple weeks its been running bad while I've been messing with other issues like timing, vacumm lines, butchered harness wires, etc. Yesterday I pulled my plugs and noticed they're all fouled already.
Why would anyone swap a 307 for 3.8? Hopefully you figure out this mess.
