87 Monte SS build
T-TOP TONY
478
406
san bernardino, ca
Your shop looks like mine. How did you support the body and drop the frame?
We used two jacks that can reach pretty high. For the front I used a 4×8 piece of beam to support underneath the floors, and then jacked it from the center. For the rear we used a big block of wood and placed it on the two rails where the fuel tank straps bolt onto, and jacked it from there. It was sketchy but we got it done. By the way it was 3 of us. So if you have some friends, just have them give you a hand.
Built6spdMCSS
5,839
9,776
Florida Beach
Anyone know where I can source a proportioning valve, I am using the inline tube stainless brake lines, and will be running disc brakes all around.
You will need the Disc/Disc Combination Valve, that's what it's called. Pics of one here in my thread, looks like the link is broken at the moment but that is who I got it from at the time and been working fine since I put the C5Z06 Brakes on the front.
Rocknrod
All Around Good Egg
98
88
That's what they say.
Tony1968
2,328
5,148
NW Indiana
An old trick i used to get the front springs compressed with no weight on front end is to use a chain along with your jack. Use the chain under and behind the front wheels of jack looped all the way around the frame. Use padding on frame areas where chain wraps. When you jack up lower arm it will compress no problem and it's very safe. Hope my description makes sense.
T-TOP TONY
478
406
san bernardino, ca
Appreciate that 🙏🏽
T-TOP TONY
478
406
san bernardino, ca
I'm still missing some parts to continue with the suspension part of the project. So decided to tackle the headlights today. Can't wait to see these on the car.
Tony1968
2,328
5,148
NW Indiana
Looks good 👍. I don't know if you mentioned but what head lights are those? Halogen, Led, projectors?
mclellan83
4,358
9,775
Pgh, PA
Was gonna ask the same, hoping they are projectors for HID or LED
T-TOP TONY
478
406
san bernardino, ca
They are made by Dapper and they are actual glass. They do have projectors and you have the option of bulbs. I got mine with the LED bulbs.
mclellan83
4,358
9,775
Pgh, PA
I wonder how the demon eyes would do in there?
