BUILD THREAD 87 Regal Build
Should I go Olds 350 or Ls
  • Ls engine
    Votes: 9 52.9%
  • Oldsmobile 350
    Votes: 8 47.1%
  • Total voters
    17
  • Poll closed .
El Correct O!
I see some guys on here that used the word "Budget" and I'm thinking not at my house. Budget is relative to disposable income and priorities. There are some budgets on here I'd love to have.
it is relative,i see some stuff folks buy on here and i say damn good for them..👍
Nice progress!
I'm impressed what you're getting done in the that small garage in the winter.
If you decide that you need buckets and want a center console I've got one (also in st Paul area) that's just missing the lid.
Maybe I'll see it around this summer? Gives you a target date to get it done 😉
I’m following now.
Love this, and I’m in with the NA LS3, but……….carb and LS is like a cats and dogs - to me haha.
Your car , do what you want. I’m just picking. But a single box to run the coils and TB would be a clean setup.
Looks like you have your work cut out for you with body. Geesh, it didn’t look that rusty in the previous pics .
Keep the faith brother and get r done.
Hey thanks, I was also surprised how much rust, ugh. We will see after blasting how she looks.
As for carb, that's just to break in on run stand. My friend that builds and turned me onto the ls runs carb in his car and it is pretty fast. I ultimately would like to run the Holly Terminator X with Trans control. But seems like a ways out.
Reactions: 64nailhead
Nice progress!
Thank You, I work with what I have, as long as it's heated I'm good.
I bet my Dad, burnouts by May Day. I am not sure I can but I am going to try. He doesn't think I will ever get it done and gets overwhelmed just going in my garage.
What color is the console and seats. I too have a console with no lid, but it is light grey and I'm not sure what I'm doing yet with interior.
Ps Look for the Regal in primer.
Sounds like you probably know this already, there is not a more economical way to run an LS and 4L__E than a Terminator X Max. Budget might not be your concern, but functionality is great. You can always use a Dominator as well, just more than double the price.
May is a goal, good luck. Your wife must be understanding lol. Very attainable, but plenty of time will be invested between now and then. FWIW, I like how you think 😉
Reactions: RegalRegal
I don't have seats, sorry for the confusion. The console is Santa suit red. Came out of a 78 turbo regal.
There is a set of decent-ish high back non reclining buckets in brown at the yard in Willmar missing the seat tracks if you are looking for a set of good core OEM buckets.
He talks about having 2 machines set up, one for sheet metal, the other for frames 'n such.
He is good at his craft by de jeesus by.
You'll know what that last part meant...
R.
He makes a lot of his own tools too.
Favorite vid that got me to watch more was grafting a 2014 fuel door into a 68-72 truck box... he calls his method "cut 'n butt" (with a very good explanation)
Reactions: RabbitHoleSS
Yes, I was very impressed with the Holley product line. Im leaning towards the Terminator X Max. I have winters off allowing me to work on it more than some, but sadly that limits what I can spend currently. Once I get back I can buy some of those bigger items. Yes my very wife is understanding, I got a good one.
R.
Thanks, he is very skilled and full of knowledge, definitely a motivator. When I watch someone do something , I get the motivated and think I can do the same thing with practice. Maybe?
Gotta start somewhere.
Good enough for what you're doing.
Wire diameter works for/against you here. You want to use thinner .023" wire for the thin stuff. Thicker wire makes it harder to dial in the machine for good penetration w/o blowing the base material away. Thicker material like suspension brackets or equivalent (> .125") you'll want the thicker .030". Thick stuff that needs some heat, I like .035".
Finally switched out wire and boy that helped alot. Definitely more control of the heat going into panel.
For some reason I never looked into that.
Thanks again.
