A/C orfice tube help needed!
Turbo Zach
2,534
5,874
I worked on it some more. I got a few more pieces out, but no big pieces. I rather not rebuild the a/c box right now. I have other things I would rather work on. If I replace the evaporater I might as well replace the heater core, and then there is the gaskets! Sounds like a hole can of worms to me. When I looked on Rockauto for evaporators I seen they sell a evaporator repair kit. Looks like you cut off the tube where the orfice tube is and replace it with a splice tube. Not saying that is a good option, but shows there is a problem getting the orfice tubes out. I will keep trying to get it out and if I mess the tube up, I know what I will have to do.
tc1959
3,963
1,975
Surprise AZ.
Those repair kits leak almost every time. The removal tool is cheaper. Just Google AC orifice removal tool.
melloelky
4,177
9,611
mass
seeing that you've got a broken one on your hands,try screwing a long dry wall screw into the brass center,hit it w/some lube and see what happens
Turbo Zach
2,534
5,874
That is exactly what I did! Thank you for the advice and every one else.
19,993
Nice!!
lilbowtie
3,460
3,965
Canton Mi
Have to remember that one if all else fails. Don't you like some of those easy jobs that turn into hours - days.
