Forgot to add this upgrade. Speedway gauges...
Part of the reason for the gauge swap was to do away with the damaged original cluster and wiring. I discovered this shortly after I got the car on the road. It had happened before I bought it and melted a section of harness together. I repaired the harness and bypassed a couple really damaged pins but I just didn't like the idea that it was there.
Plus, there was never a factory tach, and the temp gauge, oil and charge idiot lights were no longer usable after the engine swap. On top of that the speedometer wasn't very accurate because the clockspring that returns the needle to O has gotten week so it always reads fast. I started by gutting the factory cluster. That was actually more of a chore than I expected. Probably took 3 hours to get it right.
Then I made a center panel to go where the original radio goes. Looks like wood but it's actually plastic or acrylic.
All installed. Indicator lights are for high beams, CEL, oil pressure, and charge. Radio was relocated under the glovebox.
I still need to install the fuel sender and wire up the charge and oil pressure lights. I did the gauge install the night before I went racing and got tired about 1am so I quit before it was actually all done. I love knowing what's actually going on under the hood -- and finally having a tach is great! I now know that I have great oil pressure (80+ cold) and I now know where the tuner set my rev limiter :wink: .
