Part of the visual inspection in Pa for my county. Hell I even have a smog pump just to be there for that reason. If I get fustrated enough I might just have to "customize" them for better flow.Cats?!?!?!?!?!?!?!?!?!?!!?!?!?!?!?!?!?!?!?!?!?!?!?!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I know, after all the fighting with that tail pipe something stupid like that would happen. I'll fix it with a body lift & 22's. Working with how everything is going to hang & the gap between the X-member & the cats as if they were to be directly under them. The X-pipe is being used to also help in gauging clearance so when I make the two pipes to replace it everything still clears.Just wait until you put the body on, and it hits the floor!!!
No sniffer type test in my county but the state requires for visual the cat, EGR, PCV, smog pump, vaper canister. As long as they are "visable" on the car I'm good. I'm actually set up to add injector tubes just incase there is/has been any changes since my last check on the law. When I did the first engine swap I ran dual cats cause I still lived in Pittsburgh & Allegheny county does sniffer test, they helped to get my pass. If I ever find out there is a change on the visual to where they won't check I'll be tossing what I don't need. The cats will be installed for easy removal if they don't end up getting "customized".WOW really in PA???
I would gut those suckers now
You are going to hate me...
You need to move that x-pipe as close to the output/tailshaft as possible. The way you have it now is going to cause massive issues with driveshaft interference (especially when the rearend droops).
I was faced with the same issue with the wagon and cats (at least you don't have long tubes)... hence the heavy amount of fabrication on the x-pipe to make it all work.
