Did alittle bit of calulating of needed cuts in the back side of the passenger side tail hoop over the axle to drop it to matchthe driver side. I'll need to drop 1.5"-2" to be close. Then was able to see where those inches were ment to be, the strait section before the up bend to the hoop is about 2" shorter than the driver side. If I add to that then the tail ends could be even at the bumper as they are not right now. It's amazing who crappy the QC Pypes has. Now to the down pipes. It is looking more that I'll have to work in a 2.25" section at the manifold flanges, too tight with the studs to run 2.5" there. Maybe I could see what ARP has & use some bolts in place of studs But I think the heads diameter might still be too big. For how tight I want to have the 45 deg bend on the passenger side I am thinking to run 2.25" to a 2.5" adapter to the cat. For the driver side I'll need a 80 or 85 deg bend but I can't find a pre bent 2.25" section anywhere, just in 2.5". The theory with 2.25" bends would be to take them to a shop to flair the ends out to fit the doughnuts, not having to adapt that close to the manifolds. As long as I have some steel pipe sections I'll hack them up until I figure the best combo for everything to work. Maybe I should open my own shop from all this over engineering I'm doing for manifolds.
