Add On gauges - Mechancal or Electric?
Aftermarket gauges - Mechanical or Electric? And Why.....
  • Mechanical
    Votes: 6 46.2%
  • Electric
    Votes: 7 53.8%
  • Total voters
    13
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
Mechanical for the vitals.
I totally agree, 2 5/8" mechanical oil pressure and temp on the top row and electric 2 1/16 fuel fuel and volts on the bottom row. I had no room for a mechanical blinker fluid gauge tho.
pagrunt
9,154
15,314
Elderton, Pa
There are other dimpled spots on the firewall that are for factory holes. Find one that is in a location that best suits access to the engine side sender locations.
wonderboy24
1,322
1,300
Davenport, Iowa
i run electric
-83MONTESS-
4,570
967
Bellevue, Ohio
After reading some comments here it kind of baffles me that people have issues with running the senders through the firewall. On the 3 g-bodies I have used aftermarket gauges on I have simply run my senders out of the same hole that the speedo cable comes through. I have fit a -3 braided oil line and water temp lead through it with no problems. I have yet to drill a firewall.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I meant I had no room for the gauge for the blinker fluid. I would have had no problem getting the 4 SS braided lines through the firewall.....:cool:
-83MONTESS-
4,570
967
Bellevue, Ohio
Blinker fluid level or pressure? Guess its time for you to put the gauge on the cowl panel!
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
geeeeze, good point, I just had the fluid level guage but I'll be adding the pressure gauge to my wish list, thanks...cowl panel.....hmmmmmm..(y)
