What's the wire on the alternator plug hooked to? It needs to be hooked to an output and programmed to charge. Who did this install and have you asked your tuner?
PIN 15 | wire clr: BRN | circuit No. 25 | Charge Indicator Control (MODELS WITH GENERATOR BATTERY CONTROL MODULE, REWIRE ALTERNATOR BROWN WIRE TO THIS PIN TO REMOVE GBCM) |
PIN 75 | wire clr: GRY | Circuit 23 | Generator Field Duty Cycle Signal (MODELS WITH GENERATOR BATTERY CONTROL MODULE, REWIRE ALTERNATOR GRAY WIRE TO THIS PIN TO REMOVE GBCM) |
So what are you going to do?
here is a walk through of the 1986 Monte Carlo...![]()
2 pin 2006 + alternator. Don't throw it away!! - LS1TECH - Camaro and Firebird Forum Discussion
Conversions & Swaps - 2 pin 2006 + alternator. Don't throw it away!! - I just swapped the regulator in my alternator from 4 pin to 2 pin, so now it's like a 2006 or newer alternator. Why??? Because GM thinks it's better than the older 4 pin one and they must know something. Oh but everyone says...ls1tech.com
