Hello, I recently purchased a 79 Malibu. Was originally a 264ci with a 4 speed. Previous owner swapped in a 350 and put a automatic in. It has all aftermarket gauges and the interior is fairly beat up. The body is OK, no rust to speak of.
First Problem is kinda different. Lights, Been messing with them for a while. to no avail. They have just been acting weird, sometimes they work sometimes they do not. Turn on the left blinker, no blinkers up front but both left AND right blinker in the rear are flashing. Just super weird stuff like that. Well, I was working on it into the dark hours and just decided to call it a night, hood was up and the car was running, I still had the light switch on(no lights) Shut the hood and BAM!!! all lights worked blinkers worked everything just fine. So I popped the hood again, all lights went off. HMM, slowly closed the hood and seen that as soon as the latch touched the front clip it sparked a little and all lights came back on. I have been chasing this problem for 3 days straight! So long story short is I think it is a grounding issue and where would I start?
Second Problem. Car starts fine, runs fine but when I turn the key off the car still runs. I have to go to the engine bay and pull the plug on the alternator. Tested a couple things and if I leave the plug off the cars starts and shuts off like it is supposed to.
The plug has 2 wires. A red one that attaches to the alternator post. The second wire is yellow and goes to the cab and has a split to the electric choke(not sure if that is correct). The main wire coming off the post goes to the starter and splits off into the cab.. I have not been able to find it under the dash yet. So I am just not sure how to go about fixing it.
Thanks for taking the time to read my story here.
