Alternator going bad?
Gremlinsteve
345
426
Reason I'm asking is I just replaced my alternator
It started showing a discharge most of the time on the factory gauge
So I replaced it and I'm showing a discharge still
At idle it's dropping down to 8-9 volts indicated
And at 2500 rpm cruise it shows a 12-12.5 area tops
Measured at battery terminals at idle I'm seeing 12.22 volts
Is the new alternator bad also?
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
Sounds like it. You should see 14.3v all the time...
melloelky
4,162
9,569
mass
With the engine running carefully take a screwdriver and place it on the back of the case.if the driver is strongly drawn towards the back it's charging.
Zspoiler
Jun 3, 2018
85
55
Take it back f you are not satisfied with it.They can bench test them at the store.And if you still have issues,Then you know its not your altrenator.
9,614
12,683
I would do all of your testing with a volt meter and test from the output terminal off the back of the alternator and disregard anything your factory gauge tells you
airboatgreg
2,868
3,115
What kind of car?
Alternator type?
gauges or idiot light
airboatgreg
2,868
3,115
make sure you have 12volts to rear of alternator and to red wire that plugs into regulator. Brown wire is turn on so unplug 2 wire connector, start propulsion plant and see if you have 12 volts. With engine running see what your voltage is at the rear output, if it happens to be real high you have an open wire. Rare but something to think about.
If all good bad alternator.
