Alternator going bad?
Your alternator is charging at 13.8 volts. I would look at the fusible link, mine blew and no charging. Also the bulb must be good in the idiot light or no charging as well. I also ran a 4 gauge battery cable to the main battery post on the alternator to the battery positive.
Reactions: pontiacgp
The housing of the alternator needs to have a good ground before the alternator will charge properly. Sounds like the alternator may not be the problem if the new one didn't cure the problem you had.
Funny, my 87 GMC truck is doing the same thing. I replaced alternator with a high amp 12si . It charges fine till AC is on high. I'm thinking it might need the blower motor changed. It's drawing some mega amps to do that.
Reactions: fleming442
So the alternators that you have bought at a store and taken back were they tested at the store and verified faulty?
No
I planned on doing to today
But I'm checking things off as I get suggestions on things I have not looked at yet
Like the fusible link
Ok
13.8 ac off at stud on alt
12.2 with ac on
12.3 volts with plug unplugged from alt at idle ac on
12.3 volts measured at red wire on plug
12.2 volts at the positive terminal on battery at idle
Ac on or off
I know the alternator is regulating. It drops the engine rpm with it plugged in
I am irritable and it sounds to me like ya'all are going down the rabbit hole.
We have 13.8 on output so it's charging, rev to 2k rpm and see what you have. Check belt tension. I think you are fine
This shows what it's doing at 1k rpm
