Alternator going bad?
Ok
13.8 ac off at stud on alt
12.2 with ac on
12.3 volts with plug unplugged from alt at idle ac on
12.3 volts measured at red wire on plug
12.2 volts at the positive terminal on battery at idle
Ac on or off
I know the alternator is regulating. It drops the engine rpm with it plugged in
Pics
It's as if the alternator is not charging properly though
I'm going to remove it and return this thing
Replace with another
Could he not disconnect the battery with the car running, and if the engine dies the alternator is pooped?
That's dangerous to do these days, especially if there are any computers involved. I think it's a weak alternator, and I'd take it back. Or, buy a new one, and return it as not needed after the swap. FWIW, I went through 3 Mexican remans DOA from Carquest, and finally got a Chinese that worked. 4th times a charm....?
Reactions: pontiacgp
how did you determine the alternator you had on the car was bad before you bought another one
I would be looking at the battery. 13.8 is OK( ish) at the lug on the back of the alternator. Bad / weak cell in the battery can be pulling the voltage down
