Since you know the alternator is good then I'd be looking at the diagram and going through the wires till I found the problem.
prico1976 said:thank you for all your help guys. i know for sure is not the alternator. i pulled out the alternator and put it in my other cutlass to test it and is charging fine. i must have a wiring problem. with the engine running from the two wire connectors i get 12v on the red wire and on the brown wire i get 2.7 volts. when i do the same test on my other car with the engine running i get 12v on both wires. so what can be my problem this is so frustrating.
