an alternator that would not put out enough for the car the battery would drain. He has put on 3 alternators that he says burnt so I don't think they would all be junk remans
Its a ac Delco regular alternator I do have a sound system but I highly doubt thats the issueWhy? Stock is like 65 amps I think... These things didn't have much going on to eat up a lot of power, and he says he's got an LS swap so whatever it came out of probably required more juice than a typical G body.
I was worried my sound system would be a drain on the stock alternator in my elky... But it doesn't seem to make any difference. Volts seem to read just a little lower than before, but it's still close to 14 and the lights aren't dim or anything.
My bet is they're just junk reman units... Made with substandard parts.
which alternator is it?
How to Identify Your GM Alternator
How to Identify Your GM Alternator. Figure out what the difference is between 10Si, 12Si, AD244, CS144 series alternators and more.alternatorparts.com
Ok which one would u recommendyou need a resistor is the L wire....
Thanks so much ill keep you guys updated when I finishyou can use an 85 ohm 5 watt resistor
