Aluminum Radiator saved me in town
FastCraig
407
594
Huntington, WV
Was that an open blade electric fan? Hopefully that new fan moves enough air. If not, you can probably fit 2 in there.
It's a 16 inch, 3200cfm I believe. I used the plastic zip tie type rods with locking nuts. This kit isn't exactly the same as what I used but similar.
9,619
12,709
I always use a small diameter fully threaded steel rod and rubber washers and then fender washers and locknuts on both ends, never had a fan move.
FastCraig
407
594
Huntington, WV
When I pull the engine for my LS swap I'll do that too. The kit I used came with the fan.
