Antenna hole for car cover
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
  • Wow
Eric1971
7
11
Hi. guys, this is my first post on the forum. I apologize if I've posted it in the wrong place. I have an 88 Monte Carlo SS, that I just bought a fairly expensive car cover for and I want to put the antenna hole in the car cover in the right spot. Any suggestions? Also, the antenna is not a power antenna, but will the mast screw out of the flange nut that sits on top of the fender? Thanks in advance.
Thanks everyone for the comments. The mast came off perfectly. The easiest thing I've ever done to the car.
abbey castro
1,048
1,318
Harker Hts TX
Yup, power antenna was not an option on SS, yet you could get it on other G Bodies! I put a power one on from a Pick n Pull Regal with the harness and mounting brackets. Fit perfectly inside the fender, had to remove the inner well to install it, but it looks good and works great. I wired it to a relay with an up and down switch by the radio, as it wouldn't work with the existing wire harness that the car came with. Apparently the Buick harness has some other connector at the radio I wasn't aware of. After market power antennas work too. I took a gamble as to whether the used one would work electrically at all.
Best thing is to remove the mast!
