That is great news and nice job, now we can come to you with quadrajet issues...
i installed a blue print bp3503ct1 engine in my 81 malibu last summer. it has vortec heads and a hyd. roller cam,.495 int .502 ex and dur at .050 .221i .226x. i run a edelbrock model 1904 (t think thats the right number). idle at 16 in. vac. and at 2100 rpm cruise 21 in. vac. idles at 800 rpm very good. i went up one jet size,opened the idle tubes a couple thou and opened up the idle mix. holes per Cliffs book. this q-jet runs great. i run an edelbrock performer intake. most q-jets were never intended to be used with big street cams and do not perform well. also i run a locked out dist. with 34 fixed. 3:73 rear. i have had hot rods since the late 50's and this set up is very responsive and hits very hard. i had thought about f.i. but this set up is on it and you know the saying about if it's not broke. try to get a few spares (they are still cheap if you look hard) and study Cliff's book and you will be rewarded. these are outstanding carbs. and can be made to work on any engine. hope you work things out. DennyHey guys, what’s up.
I’ll get into more particulars of my issue with this QuadraJet later in this thread, but for right now, a simple question:
Is it possible to have a QuadraJet run on the primary circuit rather than the idle circuit?
My car WILL NOT idle on its own after starting it, even if it’s already up to operating temperature. It just stalls. If I very carefully feather the gas and hold the rpms around 800-1000 where it should idle, the engine sounds normal and you can hear the lope of the cam as you should.
But as soon as I take my foot off the gas it just stalls.
The only way I can get it to stay running on its own is if I rev it to 3500-4000 rpm, then it’ll stay running but it’s pig rich and doesn’t sound like it should. Revving it to anything less than these rpms won’t keep it running.
Once it does stay running this way, I can drive the car around for hours through start and stop traffic, and it pulls good throughout the rpm range but as soon as I shut it off and go to restart it the cycle starts all over again.
It’s almost as if when I rev it into this rpm range, it fools the carb into running on the primary circuit rather than the idle circuit. Is this possible?
I’ve gone through countless hours and trouble shooting only to find nothing out of the ordinary. It’s recently been rebuilt, no vacuum leaks, throttle shafts have been bushed, tinkering with the timing and vacuum advance pulloff locations has no effect on the problem. It seems to be an issue with the idle circuit, but unable to determine what. The idle mixture screws are turned out the recommended 3-3 1/2 turns.
The carb was thoroughly cleaned and air blown through all the passages when it was rebuilt, so dirt or contamination is highly unlikely. And yes, I have already bought the Doug Roe QuadraJet book. I see no mention of the problem I’m experiencing in it.
Please help before another QuadraJet finds its way onto the scrap heap. I’m at my wits end with it.
Yes, the Edelbrock parts are interchangeable. Primary metering rods need to match the series of carb, the secondary rods fit all years. The CV, found on most 70's carb or the CK rods which Edelbrock have discontinued should be ideal for your carb. Probably the CE rods and K hanger are your best bet for your current set-up from Edelbrock. I would also adjust the secondary air door opening, also in Cliff's book and make sure the secondary throttle bores are opening all the way as well.
Here is another source of parts.
https://quadrajetparts.com/quadrajet-secondary-rods-c-128_44_49.html
As stated, grab as many as you can to cannibalize for parts. This is a situation where the interweb is your friend. There are quite a few Q-jet parts vendors out there and parts are actually more available now then back in the day. I got this assortment on Ebay and it covers a large range of jets. But get Roe's book first so you know what to look for. A general rule of thumb is that you need to go at least 3 jet sizes to feel any difference in the seat of your pants. 1 size change may register on sophisticated equipment but you'll never feel anything. That is why I suggested #73 jets but if the #69s work then that's fine. Also look for a vacuum gauge on any car parts vendor site or Ebay as they are cheap and plentiful. https://www.ebay.com/itm/ROCHESTER-QUADRAJET-CARBURETOR-HIGH-PERFORMANCE-TUNING-KIT-JETS-9-PRS-SPRINGS/320931072732?hash=item4ab8fb8adc:g:ZcsAAOxydlFS0a~8
Donovan, not wanting to sound like a survey but on a scale of 1 to 10 how hard was it to disassemble, modify and reassemble your quadrajet. I think guys like you give more incentive to others to work on their quadrajets than some of the experts on the forum ,
