battery disconnect with key?
I wonder if the alarm kind that you mentioned earlier would work? I know that they were on late '70's maybe early '80's Fords like the T-bird's, on the drivers side fender. They were also on the Lincon's. Maybe check out the junk yard and see what they look like. They might work as a disconnect. Let me know what happens.
If you're looking for security, wire up a high current relay to your keyed switch. Run the power for the car (not the battery cable) through that relay, or a separate relay for each wire coming off the starter/battery that provides power to the fuse panel. If those relays are well-hidden, you could hide the keyed switch behind something like a 12v socket cover.
well i was thinking of buying 2 of these
and 2 of these
and then cut one of each apart to see how i can mount them together and use that as a prototype.
kinda like this
it aint photoshop, but its the best i could do with ms paint. :lol:
That's pretty clever. If it works you could probably sell it online for some decent money. It's the American way!
AMERICA, **** YEAH...! :mrgreen:
the only problem i think i will encounter is if i do make them, there gonna be EXPENCIVE! :|
3 words that made Amerika great....
MADE IN CHINA
so, if there was a VA hospital in china called "VA CHINA", would everyone call it p*ssy for short? :rofl:
anyway, does the plastic one lock/unlock with a 1/4 turn or 1/2 turn?
:bump:
the problem is finding one that can handle the amps our cars put out without melting or heating up. i mostly want it because i rather throw money at a battery disconnect switch than actually find the drainage problem causing my batter to die. :lol:
Thats funny ..lol :rofl:
