My car doen't have that strap hooked up and the battery doesn't drain at all. It is supposed to connect from the firewall to the top bolt that attaches the transmission to the engine. I would hook mine back up but I can't get the bolt loose.
That's where you are wrong do a search on engine ground straps and you'll get 100 hits and do some reading before you say something that's not true. The electrical system in a car is all connected somehow or another, a bad ground or lack of one WILL cause the charging system to be weaker than it should be! Here is just one statement i found on the internet from a specialist.Doober said:There definitely needs to be a good ground to the body, I never challenged that. It just doesn't have an effect on the charging system itself.
Places to check for voltage drops include the positive and negative battery cable connections, the alternator BAT+ power connection and the engine ground strap(s). Poor ground connections are an often overlooked cause of low charging output and alternator failure. Voltage drops on the positive side of the charging circuit can cause undercharging. Voltage drops on the negative side can cause overcharging (fools the voltage regulator into thinking the battery is low).[/quote
