Battery Dying After Engine Swap
carmangary
633
My car doen't have that strap hooked up and the battery doesn't drain at all. It is supposed to connect from the firewall to the top bolt that attaches the transmission to the engine. I would hook mine back up but I can't get the bolt loose.
84GP455
779
96
Methuen Ma.
I'm not saying that it will cause battery drain for every situation but, it will definitely make your charging system weaker than it should be.
shotgun
1,067
81
48
Nort o Philly
Don't like one wires at all.
Anyway, unhook it for overnight and see what happens.
jrm81bu
3,000
48
Antwerp, OH
What is the negative battery cable bolted to? The end opposite of the battery.
79loserbluebu
960
20
Illinois
IMO the battery ground should be hooked up in two places, the body, and the engine itself. Also, the engine should have that ground strap on it... If you don't hook the battery ground up to the engine, the current can travel through the engine to that little ground strap in the back. You have to think of electricity the correct way, electricity flows negative to positive.
gto78
158
Port St Lucie, Florida
I've had this problem in the past. Each time I just put my ammeter between the battery and the battery cable with the car turned off. You should only have a few milliamps for the clock running. However in my case one time there was about 1/4 amp draining. I pulled fuses one at a time until I got the ammeter to suddenly drop to zero. The fuse was for the radio. This is common, a radio will go bad and start draining much more energy than normal.
Another time I had a bad alternator, it would charge the engine when running, but then when the car was parked the alternator itself was draining the battery. That one was much harder to figure out. I found it as a last resort when I removed the wire from the back of the alternator when the car wasn't running, and got a spark. I put an amp meter in between and was getting about .4 amps into the alternator with the car off. The new alternator was fine, problem solved.
Have you tried pulling fuses yet to see which circuit is draining the battery?
84GP455
779
96
Methuen Ma.
Doober said:
There definitely needs to be a good ground to the body, I never challenged that. It just doesn't have an effect on the charging system itself.
That's where you are wrong do a search on engine ground straps and you'll get 100 hits and do some reading before you say something that's not true. The electrical system in a car is all connected somehow or another, a bad ground or lack of one WILL cause the charging system to be weaker than it should be! Here is just one statement i found on the internet from a specialist.
Places to check for voltage drops include the positive and negative battery cable connections, the alternator BAT+ power connection and the engine ground strap(s). Poor ground connections are an often overlooked cause of low charging output and alternator failure. Voltage drops on the positive side of the charging circuit can cause undercharging. Voltage drops on the negative side can cause overcharging (fools the voltage regulator into thinking the battery is low).[/quote
84GP455
779
96
Methuen Ma.
Here's another informative web site,,, read on! http://grassrootsmotorsports.com/articles/zap/ I am supplying proof that an engine ground strap does effect the engines electrical charging system, where is your proof that it doesn't>>>?????
Doober
1,253
20
38
Swartz Creek, MI/Tucson, AZ
I see no proof of a ground strap affecting the charging system in that article. I don't need an article to see how an electrical system works. I've worked on them enough myself over the years and had enough education on the subject to know that a ground strap to the body has no effect whatsoever on a charging system. Try it yourself... disconnect every single ground from the body to the block, from the battery to the sheetmetal, and from the battery to the frame, leaving the only ground to the battery through the engine block. Nothing will work or light up inside the car, but it will still start and run. I guarantee you will still see the full voltage output from the alternator at the battery. If doing this and seeing it with your own two eyes isn't enough to convince you, then I'm through arguing the topic, because you won't get it. To argue this point as far as you have demonstrates your knowledge on how a charging system works.
I'll rephrase another way... maybe you'll catch on.
For a charging system to work on a typical car, you need a functioning alternator, something to energize the regulator inside the alternator (voltage source), a ground path from the alternator's body to the battery (through the engine block and through the negative battery cable[/i]), a positive cable that 99% of the time is run directly to the battery, and a running motor.
