Bead seating tricks?
Supercharged111
4,943
7,740
Colorado Springs, CO
That is if there's any gap to get the air in
Y beat me to it. And yes, it's loud AF. If you're picky about your wheels, you might put something on the rim to protect it.
Dayzedandkonfuzed
971
1,268
Anglemont, BC
wear your hearing protectors. its louder than a who concert.
That is a must. I used to need one of these every so often doing tractor trailer tires, gotta have a good hold on it too.
Quoting my own post here... I dont think that not having a gap would matter, bead blasters strong enough to make one lol
10,571
14,316
No I am not buying another tool I have too many now. The bead is too far from the rim for those things anyway. I'm talking inches away. This stuff would work but I am going to let the shop try first. Actually if I had a third arm I probably could manage it. The shop has a tire machine so I can squeeze the bead on with both arms while blasting in air with my foot.
6,027
12,780
We use the starting fluid trick every once in a while when we can't get one to seat. Usually scares the living sh*t out of anyone who isn't paying attention. :LOL:
10,571
14,316
It does work. But I worry that it may also harm the inside of the tire. I know it works best in hot weather as it vaporizes better. It is in the 40's right now.
9,619
12,709
Maybe have someone fill it while you use those HF nylon pry bars to pull the bead closer.
10,571
14,316
I have used carb cleaner and brake cleaner for that. I wonder if propane would work? Overdoing it would probably make the 6 O'clock news.
79 USA 1
1,065
2,040
Cheektowaga, New York
I used this trick many years ago, availability of what is needed may be the problem. I had purchased a small diameter inner tube used in light trailer tires. Something that will slide over the rim. Lubricate the crap out of it and place it on the wide side of the wheel inflate it enough to cover the gap then inflate the tire. Should push out as the tire is inflated or as the tire establishes a seal you should be able to pull the tube out. just an idea that worked for me.
Turbolq4
1,732
4,207
Nampa Idaho
Back when I worked at a local tire shop we had one of those bead blasters. Bunch of pranksters working there too.
One cool October morning one of the guys was out back of the shop checking a tire leak in a large stock tank we used for that purpose. One of the other guys packs that bead blasters out, sets it down on the opposite edge of that big round stock tank and slips the tip just under the surface of the water. The guy actually working looks up just in time to get his eyelids peeled over his head by the tsunami of stank tire-checking water. I bet it moved 100 gallons of water out of the tank, totally soaked the other guy and made a lake in the back lot. Hilarious 😂
  • Wow
