Nice, that sounded good👍, I was expecting it to sound like loud *ss.Yup. Built right with a good muffler it works mint.
Natasha was in her first trimester taking videos on a very hot August day:
Wow.Its truly a balance of performance, a quality installation, look of quality, and sound your looking for. GN's (I.M.O.O) came stock with duel exhaust, and should remain this way to get the true unique sound. With that being said, no more than 3" AT MOST. Anyone who puts a 4" exhaust on a GN knows nothing about engineering, performance tuning or takes pride in the quality of their work, because you will have to either modify or hack your car to do the install. CONGRATULATIONS on your purchase and I wish you the best with your decision!
(personally, whatever you do decide to go with, I would look for a quality stainless steel exhaust to ensure a great look for years to come)
Wow.
I'm going to brag about even a stock 307 having more than 2.25". In certain spots, anyway.Also, no one brags about having a 2.25" pipe.
Don't forget the 2" crossover pipe before it, a pure Horsepower maker. Crazy they shrunk the pipe before the converter, leaving it or enlarging it even more would have helped. GM really screwed around and did anything to avoid a true dual exhaust in these years. Including the insanity MM pointed out on his Camaro, copying the high performance factory head pipes. GM used dual down pipes and cats into a single exhaust, really? I am really curious what the FE3X magic 30 HP gained system was diameter wise from the headers to the cat. Very good info when these parts become obsolete and custom parts will be needed to made for 100% correct Restorations👍. I knew the down pipe where I cut was too large for 2.25" pipe but 2.5" need goop to seal when I cut out the plugged pancake cat on my 81 Delta 88.I'm going to brag about even a stock 307 having more than 2.25". In certain spots, anyway.
2.375" to be exact. That is the I.D. of the stock downpipe from exhaust manifold to cat. I'm going to simply forget to mention that it necks down to 2.25" on the outlet side right before going into the 4-bolt flange. 🙂 GM p/n 22519894. I just whipped one out and measured one.
Go ahead, whip yours out and measure it!
Fool your GF while measuring your pipe! It's also fun at parties!
Or teach her how to use one...(wtf?)
My Dad was right. It actually IS an official measuring unit!! 🙂
Well, it does, after a certain point. If the exhaust is too fat, it won't help you scavenge well and you can hurt performance. I'm in the camp with everyone else- 3" duals if the engine is slightly warmed over, or the 4" single that motorheadmike suggested. I wouldn't go over those sizes, personally. It WILL give you more exhaust noise, but too much will just suck donkey balls. So the advice given previously is good to heed.
hmmm, don't know about other g-bodies but I wonder if that was why the El Camino had such a funky shaped crossmember? only enough room for one pipe to cross underGM really screwed around and did anything to avoid a true dual exhaust in these years.
