Want to see if any of you all have a great method for cleaning some cylinder heads good enough to get them into a parts washer. Thanks for the input!
I have used easy off oven cleaner on real greasy parts. I have used it on aluminum transmission cases too. Just didn't leave it on as long. Or local self service car wash.Want to see if any of you all have a great method for cleaning some cylinder heads good enough to get them into a parts washer. Thanks for the input!
I'm curious as well since i just picked up a set of 862 heads yesterday, and they are grimey! I used purple power on my other LS parts(straight, undiluted) with great results....I'm sure it will work just as good on the heads. I don't have a before pic, but these valve covers were nasty when i got em....this is after a couple rounds with a nylon brush.....Want to see if any of you all have a great method for cleaning some cylinder heads good enough to get them into a parts washer. Thanks for the input!
Be sure to get them real dry. You don't want the valves rusted to the guides. It might be better to break them down first.You could start with Foamy Engine Bright and the quarter carwash. If you are going to have them machined, why not just take them to the machine shop and let them hot tank them?
I'm curious as well since i just picked up a set of 862 heads yesterday, and they are grimey! I used purple power on my other LS parts(straight, undiluted) with great results....I'm sure it will work just as good on the heads. I don't have a before pic, but these valve covers were nasty when i got em....this is after a couple rounds with a nylon brush.....View attachment 68917 View attachment 68918
I know brake cleaner works good for darn near everything.
Btw, you have a nice stash of parts in that bed!
My heads are also 862's. I've got a turbo off of a 2005 powerstroke also but I don't think it's going to make its way on the car by next year.I'm curious as well since i just picked up a set of 862 heads yesterday, and they are grimey! I used purple power on my other LS parts(straight, undiluted) with great results....I'm sure it will work just as good on the heads. I don't have a before pic, but these valve covers were nasty when i got em....this is after a couple rounds with a nylon brush.....View attachment 68917 View attachment 68918
Nice! The heads were actually pulled from the same burban i got the valve covers, rockers and some misc bolts from. At least i know everything will bolt up with no issue. After a seal and spring upgrade to some btr .660's, they will go onto the 5.3 i just finished short blocking a couple weeks ago. It will get twins at some point, with a 4l80 nestled into my 87 cutlass.My heads are also 862's. I've got a turbo off of a 2005 powerstroke also but I don't think it's going to make its way on the car by next year.
