REGAL Best Place To Get Window Sweeps?
For reference, 20672476 and 20672477 are the GM part numbers for the rubber seal strips that attach to the wide anodized aluminum door top molding. They're about half as wide as the ones with the beads.
Whats the difference between the two, if they both are for the wide door molding? Is one cutlass/regal and one monte/grandprix?
The beaded stuff does NOT fit the WIDE molding itself. It's designed a little differently to go out on its own to do the job. Many people with messed up wide molding revert to just putting the beaded stuff on. Like 84 H/O and 87 442s use the beaded moldings only. I've seen people use black beaded stuff on the H/Os. Which is incorrect from a purist standpoint, but looks ok.
Regal and Cutlass doors are the same part number. The part numbers I provided are for the "chrome" beaded ones, the ones that have a black bead (GN's used those I think? Not familiar with Regal stuff that much) and the last two part numbers are to attach to the WIDE top door molding metal part. crimp-punched most of the way and riveted in the front. PITA to replace just the rubber part. I got a few pairs of each around here somewhere that go to a Cutlass (no black beaded stuff, though). If I can find them I'll snap a pic or two.
Edit: Montes and GPs are different animals altogether.
Found a wide molding in the closet. (Found a complete air shock setup too...hmmm.) Note there is no bead.
Note there are rivets and the punch through style of crimping. The inside piece of the rubber part has metal backing where it meets up to the metal molding. I'm assuming that isn't meant for much more than keeping things attached until you get it screwed into place on top of the door.
wide door trim weatherstrip 1.JPGwide door trim weatherstrip 2.JPGwide door trim weatherstrip 3.JPGwide door trim weatherstrip 4.JPGwide door trim weatherstrip 5.JPGwide door trim weatherstrip 6.JPGwide door trim weatherstrip 7.JPG
Reactions: MrSony
