700R/60E 1st gear ratio is 3.059
3.059×3.42=10.46 final drive ratio in 1st. Pretty steep for launching. The 27" tire helps though.
3.059×3.08=9.42 better but still a bit steep.
700R/60E overdrive ratio is 0.696
That gear with a 27" tire should turn 2370 RPM with a 3.42 at 80 MPH. This is good.
With a 3.08 it should turn 2134 RPM at 80. This is a little low. At 60 it will turn 1601. A bit luggy.
1st gear in a 4L80E is 2.48.
2.48x3.42=8.42 will launch well with a good high stall speed converter.
2.48x3.08=7.64 too high in my view
Overdrive in an 80E is 0.75
3.42 should turn 2554 at 80 which is quite acceptable.
My vote is a 3.42 with an 80E with a quality ($$) converter with a stall speed somewhere in the 3400-3600 range.
Hopefully this post will help you see the math side of looking at it and help you find the compromise you want. In the end, it's a compromise and it depends on what you want the car to do.
I didn't look at this from a 1/4 mile RPM going through the traps perspective. Not my area of expertise.
My daily driver (truck) has 4.10's with 31.9" tires, an 80E and a 3600-3700 RPM converter (small cam). It's fun. It doesn't launch though. It will light those 12" tires right up with ease.
It just depends on what you want but the more you tune the combination to that, the happier you will be with the car
