ok guys i have a derale thermostat (adjustable) w/ built in relay etc. its what the guys at derale recomended to me for wiring in my dual fans. anyways im worried they might draw to many amp possible although i was told they were within spec of the relay. but i have 2 relays i can wire in if i have to. So what would you recommend the best way to wire up the system? i notice the derale instructions call for using the ground as the switch. also i will use a switch on the ac circuit as the overide/backup.
heres the instructions
http://static.summitracing.com/global/i ... -16749.pdf
