Hello All,
For my 1987 Oldsmobile 442, I recently did the blazer spindle and corvette brake swap. And I noticed you lose the blazer backing plate when you go to the larger corvette brakes, the adaptor kit supplies shims to make up this distance. Instead of using those shims I decided to build a plate to run 3in brake ducting.
I first started with one of the shims to take measurements off of it to created a bracket in fusion 360. The bracket was then sent to sendcutsend to be laser cut. I used a 3in steel exhaust pipe to make the ducting inlet and welded it to the bracket.
The ducting bracket is bolted between the steering knuckle and hub, I’m waiting on the ducting to arrive, I also fabbed up a ducting inlet and waiting for its delivery.
