I just came across the Caliper I ordered for a 78 Seville which was advertised to have an SAE bleeder and Banjo but turned out to be metric. GM changed the banjo bolt from 7/16" x 20 in 77 to 10 x 1.5 in 78. I think they did that to prevent a conventional caliper from being installed on a 78 and up vehicle which has low drag calipers.
1978 - 1981 Camaro Front Disc Brake LH Single Piston Caliper
New 1978 - 1981 Camaro Front LH Disc Brake Caliper for all models. Great replacement Caliper at a great price! This 78, 79, 80, 91, and 81 single piston brake caliper is remanufactured to meet or exceed OEMwww.camarocentral.com
1978,1979, and 1980 f-bodies didn't come with low drag calipers as their master cylinder were normal strait bore master cylinders. It looks as if 1981 F-bodies came with an aluminum step bore master cylinder from the factory. This means, from the factory, the calipers should have been low drag. That being said, the part numbers for the 1978-1981 calipers are the same. To me this means they were rebuild to NON low drag, or normal, caliper standards so they can work for both strait bore master cylinders and step bore master cylinders. If the caliper were rebuild to LOW drag standards and installed on a car with a strait bore master cylinder, you would have a car with a low, spongy pedal. The rebuilders would get a lot of returns and it would not be profitable.
The only difference between the 1977 and 1978-1981 models is the metric fittings only.
After 1998, no rear drive GM car or truck came with LOW drag calipers as they stop using the step bore design master cylinders. All new cars have a normal, NON low drag designed calipers and strait bore master cylinders.
