Blower motor not blowing on high speed???
craignunez
14
South Florida
Blower motor doesn’t blow on high speed? Replaced a/c selector switch, resistor,motor I’m lost any help would be appreciated FYI if I run power straight from battery it will blow on high??
foxtrot
1,489
590
USA
With 12 volts connected directly to the blower motor it will run at it fastest rate as long as the ground is good. You'll want a fuse and a toggle switch in-line with the 12 volts, so that you can disable when not in use.
here are a few diagrams for the gbody if you need them:
http://www.maliburacing.com/wiring.html
6,834
6,744
full speed is full 12v battery power. follow the thick red wire coming from near the box.
20,397
Take a look at a connection that is on the passenger side close to the front of the engine. If that connection or the wiring has fallen onto the exhaust manifold or headers the red power wires for the fan may be burnt or the connection itself may be fried.
8,827
7,783
As said, look for the big red burnt wire.
foxtrot
1,489
590
USA
I've actually seen that connector unconnected on many G-body's over the years. I don't exactly know why.
