Bucket Seats
Sammieizzy
14
4
I want to raise my seat a little are the fasteners
holding the seat in are they Bolts or Studs
Thanks Steve
JAMCAR223
1,853
5,507
Houston, TX.
flange nuts are 13mm
vandyman
Jul 16, 2017
68
55
Instead of going all crazy on trying to raise your seat.
Just get a booster seat like the old ladies put in the cars back in the day. 😏
9,619
12,706
I would look for a Gbody power seat base then you can have all the adjustment you need, I modified both drivers and passengers side buckets in my Monte and Regal with those.
oldsmobile joe
2,067
3,053
mpls
you can add spacers between the tracks and the floor. you have about 3/8" of room before you runout of stud.
but the seats are bolted to the tracks. you could add spacers to this area and if necessary, use longer bolts.
CopperNick
3,373
3,033
Canada
Both the studs and bolts are long enough that if you want to shim them to gain height you can add something like washers. would suggest fender washers for the track to floor studs and suitable diameter and hole size standard washers for the track to seat base.
Be aware that accessing those stud nuts can be a PITA. Being 13mm hex helps cause you can cheat and use a 1/2" but you need to go with a six point socket if you can get one in there or a six point combination wrench if not, just to get the nut to back away. The location exposes them to water and crud and can make it difficult to get them to cooperate. Once free, if you have them, a gear wrench 1/2" combo will finish off the job. Also they may be hiding behind those plastic shoes or socks that are used to hide the feet of the track and which are held in place by phillips screws which tend to be self-suicidal if leaned on too hard. Joy.
Jakefromstatefarm
465
923
This makes quick work of install and removal of buckets in my experience. A ratchet/wrench will still get the job done, just takes a few more minutes and a little swearing.
