Camshaft said:Damn, dude! That looks great (and I hate Monte Carlos)!![]()
88MONTESS said:Camshaft said:Damn, dude! That looks great (and I hate Monte Carlos)!![]()
Camshaft do u really you hate Monte Carlos?
87montecarlomrc said:so is urethan paint the best? im thinking bout painting mine. is acrylic enamel glossy without clear coat
FE3X CLONE said:Looks good.
The true test will be what it looks like after a year. I've heard from multiple people that did what you did and said a year later the paint was starting to fade.
You have to go into it realizing it may not last. I mean I just priced the base coat paint for my '87 at the paint store it alone was $300. So for them to do it for $250 you know they're not using quality paint.
carmangary said:You have to know what you are doing. You are not supposed to use urethane on top of laquer unless you use a sealer in between. The original paint on my Cutlass is laquer so I can't just scuff and shoot urethane on top. I'd have to sand, use a primer sealer, primer, then urethane paint. That is costly. Or, I could just sand it down a little and shoot some more laquer on it and it'd be ok.
When you paint, it is just as important to know about the old paint as it is to know about the new paint because they have to be compatible. So, before deciding what you will use, figure out what you have.
