Build or part it
grandamman
809
415
up in the hills
Rust on the doors like that usually means bad news underneath.
Otherwise, Grand Am front clip, cut the top off and baja it until it folds.
81Regal
1,557
485
83
Terril Iowa
Kind of funny how many people are scared of rust, I guess Im just used to it so thats a not an issue for me. After all these are at the newest 32 years old. I agree with the ones that say the A pillar and cowl is damaged just a question of how bad. The front stub on the frame looks to be slightly bent but that was in front of the swaybar. It has a damaged control arm where it was hit, would have to do some measuring to see if the frame is bent there.
Ribbedroof
4,905
7,013
Wellston, OK
They're bad about collapsing the engine crossmember in a side hit
Cowl/pillar should pull....if not rusty
Clutch
5,189
10,913
Brick NJ
There's like 4 guys on here that could fix that car properly. I'd be willing to bet on Cowell damage to the lower A pillar a bad upper control arm and the top of the right rail being ugly ugly laid in and probably a kink in the lower engine crossmember below the oil pan. Out of the 4 guys on here that CAN do it I think only one would and it's not this one
1evilregal
3,056
4,357
Greensboro, NC
I'd part it... years ago when I was dumber, I'd swear that I could save it, but now it just looks like more energy than I care to give....
ck80
5,743
9,122
Part it out.
Then again, elky bodies without the damage are pretty cheap around here.
But still, part it out.
UC645
1,083
3,072
Kittanning, Pa
Take it apart and inspect it.
You’ll never know the full damage until you get a good look at what you’ve got. The a pillar might be damaged superficially, but it’s most likely not bent too out of shape since the windshield isn’t broken from what I can see.
