Well, I actually had time this evening so, since I need to get this done in order to start the suspension mods, I finally got the old . . .
ratso-frackin motsa-blackin electric antenna out, hooked up the new one and . . . DOA. So, the factory antenna just ran continuously with just the battery hooked up, no ignition or radio ON required. The replacement does nothing even with proper voltages applied. Glad I checked it BEFORE I buttoned the fender back up.
For those that don't know, the factory antenna is spot welded to its mounting bracket on the back side AND [on mine anyway] the bracket was attached "from the engine compartment side" down below the heat exchanger where there is no way you can get anything on it. So, I had to break the bracket [the replacement antenna mounts different anyway]. Why is the fender only loose instead of OFF? To take it OFF requires hood removal and several more things up front [practically have to remove the entire front end] so this is just loose enough to gain access. Had the mounting bolt been applied from the outside . . . 10 minute job once you get the fender loose . . . IF THE REPLACEMENT PART IS FUNCTIONAL! So, now I get to wait for a replacement for the replacement . . .
Here are a couple of pics of the dirty deed.
Old before removal:
And after removal:
